Originally Posted by josh9mille
I would just use the flux bulletproof diffs over the Cen units, i think they are just as strong if not stronger and are available everywhere. Cen diffs are much harder to come by I think
So you think those diffs in al bulks will handle the power? I do not plan to run very heavy wheels and tires, and I can imagine the weight with batts will be around 18-19lbs.
