crazyjr
crazyjr's Avatar
01.03.2011, 02:41 PM
Is it not long enough? Or wide enough? The packI plan to use should be fine for it, not much thicker than a nimh pack, so the expansion hold down should do the trick.
The battery box is too short for the packs i run, the box seems to be set up for traxxas 6 celled packs. I run flightpower and hyperion 3700 20c's right now, just looking at it from where most pack lengths seem to range.I know some are shorter, but seems most we run are longer than standard 6 celled NIMH pack.
