Originally Posted by Shonen
If you run the Mamba Max on 4s you need to use an external BEC. The original Mambas have linear BECs, be careful running it on higher voltages than 2s. I've burnt mine running it for extended periods on 3s, even.
I was, but when I tried to use the BEC I was only running on 6 NiMH
