01.04.2011, 01:30 AM
Correction, the flux and xl dogbones are the same, so are the diff outdrives. Difference is in the outer wheel axle, the xl is longer to accomodate the spacers.
So I will stick to the flux wheels axles, BP diffs with the hd outdrives from either a flux or xl and the HD dogbones.
Now can anyone tell me what if any difference there is with the hub carrier and hubs? Both the xl and flux are marketed with improved, stronger parts, but does that apply to both the hub and carrier? I only ask as I have quite a few X hubs and carriers that I can use.
Also guessing all of the lower arms are the same, as I have a bunch of those too.
