Pdelcast
Pdelcast's Avatar
01.04.2011, 05:38 PM
Originally Posted by outlaw View Post
We have currently about 6 of those running and they are doing more than well !
Very ESC friendly and
The Test with the CC2200 KV against the 2240/7 same KV running an AE SC8
was a win for the 2240/7 even on 18/46 gearing
in
runtime
temp
power
On MMP
CC 2200
Runtime: ca. 16 min.
ESC ca. 52°
Lipo ca. 41°
Motor ca. 53°
TS 2240/7
Runtime ca. 16 min.
ESC ca. 48°
Lipo ca. 37°
Motor ca. 44°
Lipo Kokam H5 5000 mAh (older one)
Same gearing 16/46
No datalogs yet need to get the Eagle Tree working
We have a very "humpy" track indoor
Again,
i do love Castles products !!! This is not a sales meeting for Tenshock
Well, this type of testing doesn't really say anything - - really need to test on a dynamometer to be sure.
The CC/Neu 1515 motor was designed to have as flat an efficiency curve as possible, and peaks at about 90% efficient. It's possible to get more efficiency from the motor, but at the expense of efficiency "flatness." -- in other words, it's possible to make the efficiency curve PEAK higher at a particular point, but at the expense of efficiency at the extremes of the curve.
It's very likely that the two motors have their efficiency peaks at different places -- which would make one motor have better efficiency in one particular setup, and the other motor have better efficiency in another setup.
Patrick del Castillo
President, Principle Engineer
