Originally Posted by lincpimp
Interesting, so the 2500mah 40c rhino lipos do fine with the 1400 motor? I had planned to run a flightmax 6s 40c 3000mah pack if I went wth the MMpro/2400kv 1415 combo.
The 2550's work great, I ran this set up all summer long in my slash no heat problems (I gear in the low 40's). I think the 2400kv set up would be great for a 4s set up.The problem with the the truck is gearing ,with 6s 2400kv you could only slow it down to around 52 mph or so(11/54).
