NikoIGT
01.06.2011, 06:51 AM
Originally Posted by IGT_7x View Post
I think I'm going to stick with the single speed setup, I hear the 2 speed setup of the GT2 is not that good & the 2nd gear tends to get destroyed.
You could use the new GT2 tranny:
http://www.infernosonly.com/New_Kyos...sion_s/832.htm
This works better, as there is only 3 tooth difference between 1st and second(doesn't hit as hard). you set the shift point fairly low(shifts early) to minimize the damage.
