01.06.2011, 02:39 PM
Originally Posted by thzero View Post
4 Flux shocks. Use either one of the following springs:
#86553 SHOCK SPRING 18x80x1.8mm 12.5 COILS (WHIT 159gF/mm)
#86554 SHOCK SPRING 18x80x1.8mm 11.5 COILS (YEL 177gF/mm)
Standard Flux spring is
#86551 SHOCK SPRING 18x80x1.8mm 14.5 COILS (PINK 134gF/mm)
You can pick up the Flux shocks on ebay pretty cheap; granted not as cheap as the older Savage shocks, but oh well.
Looks like the shocks will run about 10 bucks each shipped. I am guessing the stock springs will be a bit weak? I will weigh my truck and you can tell me if the white or yellow springs will be better. I plan to bash it so I am guessing the yellow will be the way to go.
