_dV
01.06.2011, 06:50 PM
Depending on weight, if you use the long plastic tube and just the one spring on each shock you may find the pink spring is fine. That's what I am using but my build is a couple hundred grams lighter than a stock Flux (about 3730gm without wheels, battery, shell).
If you use the yellow spring with the tubes it will be very stiff.
