Originally Posted by lincpimp
I will try just a set of the flux shocks. Maybe add thicker fluid to them. What weight is the stock fluid? Would it be a good idea to tear them down and rebuild with some green slime? If I have to dump the fluid...might as well go all they way.
I tried 40wt in FB2 but found it to be too stiff so I went back to 30wt and used green slime
