01.07.2011, 03:39 PM
yeah, you're going to have a hard time finding a powerful charger that is powered directly off 120v mains. Most of those types are around 50w max, some maybe a bit more. For example; if you have a 5000mAh 6s pack and want to charge it at 1C (1 hour charge), you'll need a charger capable of around 130 watts.
Many lower-end and/or 120v powered chargers will charge 6s, or high currents (~5A+), but not both at the same time due to their low power limit. This power limit is pretty important, especially with today's packs with the ability to charge at more than 1C.
In short, you'll do better with getting a high current (10A+), high power (200w+), and high voltage (6s+) charger than runs off 12v. Then, just get/build a high current 12v supply. Once you determine the charger you want, this page helps you determine what power supply you'll need to take full advantage of that charger. Note that many really high power chargers (300w+) require ~24v to get their max output.
