Originally Posted by brian015
The ac6 (or similar 50w charger - I use 2 of them to charge 2 batteries at the same time) should definitely be capable of charging any 6s lipo. Since it is limited to 50w, it can charge a 6s lipo at around 2Amps. So, if you had a 5000mah 6s lipo, it would take 2.5 hours to fully charge.
And to clarify my above statement, in light of BrianG's comments - I do use an external 12v supply for my cheap 50watt chargers - and they charge 6s just fine.
