What bearings and diff will fit this? I'm worried that with all the runtime I've put on the diff and bearings that something is going to eventually need replacing. I suppose I should oil the bearings. This this diff is fairly old and no longer supported I should probably move on to a newer diff. Any ideas? It needs to be a long enough diff with the right bearings right?
CLICK
Thanks,
Zack
