Riko
Riko's Avatar
01.10.2011, 07:09 AM
6.5mm is fine... The avg amp draw is very reasonable...
I read on a board that you would have to modify the bullets to make the thick cable fit inside the 6.5mm bullets?
So for that matter a 8mm bullet would be easier to use, is this correct?
edit: Thomas Porfert answerd my question perfectly and I saw it only afterwards :)
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
