Thread: MMP Problem
01.12.2011, 10:57 PM
Those look like high output white LEDs which I assume is for "headlights", so they need to have ~20mA or more for that use. IIRC, typical white high brightness LEDs have a Vf of a little higher than 3v. So, on 6v, they shouldn't be driven enough to technically need a resistor, but obviously something is wrong.
If anything, I'd re-wire them up so instead of 2s2p, they are 1s4p. And then use the 100-150 ohm resistor for each LED. You could use a single common resistor for all LEDs in parallel, but that's not advised.
