Originally Posted by nativepaul
With 200kv you need 100Volts even to spin it as slow as a gas motor, are you working on a 30s ESC? If so how are you dealing with the safety aspect, 3x separate 10s pack inputs which are series connected internally within the ESC?
No, this particular motor and wind is for an airplane application, it wasn't designed for a car application. For car applications we will use a .5Y wind and probably a shorter rotor.
We don't want people playing with 100VDC sources.
