brushlessboy16
brushlessboy16's Avatar
01.14.2011, 12:26 PM
As Brian said earlier, the thinner laminations allow fewer eddy currents to form that are perpendicular to the magnetic field, and resist the field.
This is the same reason why high electrical resistance is a good thing -- the eddy currents that do form will be lower in power if the resistance of the steel is high.
Silver is a better conductor than copper, but costs so much that it's not practical. And it's only a little bit (I think about 20% or so) better than copper.
And it's not just the cost of the metal -- it's the processing too. There are very few manufacturers that are setup to process silver into electrical wire, and there are a few applications which demand it (some space applications.) So they command a HUGE premium. After processing, silver wire is around $2500 a pound. That would make a 1515 cost somewhere in the $600.00-$800.00 (just an estimate!!!) range.
Have you ever thought of making a limited run of like "ultimate motors"
Like a batch of 150 1515's with silver angel hair wire, 1mm air gap, monster magnets and low drag bearings..
expensive yest. but with your PR you could market it and it would probably sell out..
...not to mention that the motors would be absolutely INSANE!
