01.14.2011, 03:43 PM
Geared for the same speed the 2 motors should "see" the same load. I just wondered why the 14xl ran cooler. I just figured the amp draw thru the motor (if there is such a thing) was around half as much with the 14xl than the 7xl, and that accounted for the addl heat created. Higher amp draw seems to produce more heat as the wires and such have to transmit it.
I may be completely wrong on this, so that is why I asked!
Thanks for the replys.
