Slash 4x4 SCT 2400 combo install
crusey_aus
Slash 4x4 SCT 2400 combo install - 01.17.2011, 04:42 AM
Howdy Folks,
Just installed the SCT/2400 combo into my Slash 4x4
A couple of observations
I had to install an external bec as the internal did not work well (Ace DS1015 servo)
I am not happy with the length of the motor shaft and where the pinion sits (5mm pinion with reducer)
I am running the TRX 50t spur and was planning to install a 17t pinion
Could not get them to mesh correctly and had to install a 19t
The MMP ESC has the yellow light flashing (TX problem ?) but functions correctly and calibrates fine, any suggestions on how to fix this ?
I am running the Spektrum SR3300t RX and it worked fine with my previous MMM / 1512 combo
The motor is a little ripper, and after 10 minutes of high speed passes the temp didnt get over 130 (running a 4s 5000mah 40c pack)
Great job on a great combo for these cars
Cheers
