crusey_aus
01.17.2011, 05:49 PM
This truck runs 32p /0.8mod gears, right? Why not get a 1/8 bore 32p pinion for it, instead of using a 5mm bore with reducer? Or are you having issues with the motor contacting the chassis before the smaller 17t pinion can get close enough to the spur? Just a thought, as I am not familiar with either the vehicle or the motor.
The motor mount plate hits the end of its movement range before the pinion and spur can mesh correctly
Same thing happened when running the 1512 motor, was planning to install a 21t pinion but could only get a 23 to mesh correctly
I do have some 3mm pinions but as far as I can see they are similar in physical size
Not really a big deal as a larger spur would also help, just thought I would let people know
Cheers
