kazuaki
01.18.2011, 04:29 PM
Yeah, I suspect 2S may be more than enough, but the truck is used for bashing in large open sandy areas, so you can put a lot of power down. The webpage doesn't say the ESC won't work on 3S. In fact, it says it WILL work with 3S, but you should use a lower KV motor. The reason for my question is that I've seen the standard original Sidewinder running 3S with 4600kv motors. It also seems to me that the SC10 is fairly light compared to say a Slash 4x4.
