maxxdude1234
maxxdude1234's Avatar
03.09.2006, 03:38 PM
I use the same motor mount as you B15, and have also stripped a few spur gears. I then mounted my motor on the other side and had absolutely no problem (with Mod 0.8/32 pitch gears). I think its the torque the motor produces that causes the mount to twist, but for some reason when mounted on the other side it didn't twist - wierd. Also check that the motor screws are very tight and the motor can't slip.
These things worked for me, so you might or might not want to give them a try (I know how much of a pain it is to change spur gears with that chassis!!!) Good Luck!
