Thread: Toro 1/8 Combo
Pdelcast
Pdelcast's Avatar
01.21.2011, 11:28 AM
Pat, go get yourself a nice coffee and donut/bagel. Better yet, send an employee out to get them since it's probably snowing as much if not more than it is here a couple hours north of you.
What is it about the 4833 that makes them less capable? IIRC, a while back you mentioned something about switching losses but not sure.
Well, a couple of things.
The 4833 has a poor gate-drain/gate-source charge ratio. This means they can't be switched very hard without shoot-through. This also means they ring more, which causes more switching losses.
They also have about 30% higher RDSon, which means higher i^2R losses. (1.5 millohms for the 4901, 2.0 milliohm for the 4833)
So, in short, they run much hotter at the same current than the 4901. But they are quite a bit cheaper, and more available.
Patrick del Castillo
President, Principle Engineer
