Originally Posted by 2dialed
i'd say the option rotor should be 1/8 and the standard shaft 5mm. the motors are best used in heavier vehicles than 10th scale 2wd buggies and stadium trucks.heck i'd like to give it a try in a 1/8th buggy
Been running the 3800kv 1410 in my Losi 810 conversion for over a month now and it's doing great. Running on 3s. Of course this buggy is significantly lighter than a standard 1/8 buggy. It's weighing in rtr at just under 6lbs. Don't think it would do to well in a normal 7+lb buggy. But if the performance I've been getting from the 1410 is an indicator I'm bettin the 1415 would probably fo the job in a lighter 1/8 buggy if it was geared reasonably.
