rawfuls
roofles.
rawfuls's Avatar
01.25.2011, 12:07 AM
Again, it's not a certain fixed value. The higher the current flow, the higher the voltage drop. The 1n4001 will drop 0.8v @ ~.2A. Other resistors, such as 3A diodes (which are larger to handle V*I power losses) will drop less voltage at that same current.
Okay, so I should just be using 7 diodes if I'm dropping 12V to 7V?
