josh9mille
josh9mille's Avatar
01.26.2011, 04:41 PM
Originally Posted by thzero View Post
Hope I didn't miss anything. :) At least nothing important!
Nice things to add or change as you go along are...
a) the bulletproof diffs when your diffs blow up.
b) 4 Flux shocks instead of the 8 savage shocks. just less maintenance and they work as well or better.
c) al. bulks as linc suggested.
d) either Flux or XL axles and dogbones. XL extends the width of the truck about an inch over the Savage X/Flux trucks.
e) the adjustable upper suspension links from the XSS and XL.
f) integy (because no one else makes them) rear hub carriers which removes the slop out of the rear end
Sure others can come up with more!
oh, of course 2.4ghz running gear!
I would not worry about getting these, the non adjustable ones are stronger. I never had luck with mine anyway, or maybe its just me?
