JasonB
Flux Fan
01.27.2011, 05:33 PM
thanks for posting that thread!!!
Jason... do you really think the Hot Bodies or Kyosho plastic diff case with steel ring is better? does it accept the BP ring gear? and i also hears the spiuder and bevel gears are a little tougher too!!!
you got any part no. or links to them? thanks
Yes I do, and Yes it does; time will tell if it really is a tougher combo. I don't have the Kyosho diff case, but from the pictures it appears to be identical to the Hot Bodies one I'm using now. I've read that the Hot Bodies spider gears are tougher too, but I'm using stock Flux gears for now until I use up my spares. It's all in my post that you linked to at the top of this thread. (link)
