Took the Savage Flux out in the snow for a run today. Running stock other than the gearing, dropped down to 49/17 gearing. The parkinglot here has about 4" of snow covering the whole thing, so this was pretty much nothing but full throttle for 75% of the run. It's also about 25*F out so lipo performance suffers a bit as well. Changing the sample rate fixed the time on the graph. However this was a less than ideal setup for data logging. Since the Flux takes two packs I only had the Eagle Tree plugged into one of them. Now I know that overall that means the voltage being used is double what the reading is as the packs are wired in series. That being said series wiring doesn't increase the capacity of a pack so I don't think the Amp draw doubles.
Lipos are Turnigy 5800mah 25-35C
