01.28.2011, 12:42 PM
Originally Posted by asheck View Post
I haven't looked to deeply into it. But I know they are modding those old maxx axles to work. But it seems they are changing the ends, or just using the bigger bearing on the rear. Which the Tekno's use a 6mm bearing in their carrier, so using those on the rear, and the maxx axle, might be doable.
The tekno hubs use a large diameter inside bearing, like the revo setup. But the bearing is smaller than the revo, so it is not a direct swap.
I had a look at other hub options, and found the ofna hyper mini ste uses a rear hub that run a 6mm axle. It does use a 6x13 outer bearing and a 10x15 inner bearing. Not an issue as you can get 6x15 bearings to replace the inner, then run the old maxx stub axle that is 6mm all the way along.
P/n for refeerence:
Ofna 21025, mini ste rear hubs
ofna 11066 10x15 inner bearing
ofna 18075 6x13 outer bearing
ofna 21059 3x35 lower susp hinge pin
The 3mm hinge pin is my only issue, cannot find the diameter of the stampede hinge pins, where the hub connects with the lower arm. Pretty sure it is 3mm, and if so these hubs should fit. They may need to be trimmed, or shimmed as I am unsure of the width of these hubs compared to the pede hubs.
