thzero
01.28.2011, 07:15 PM
The Lightning Stadium Diff Cup (HBC8019).
Its used in the D8/D8T and the Vorza. So it should be relavent for some time.
Originally Posted by JasonB View Post
if you want to use the bigger bearing, all you have to do is use the Lightning Stadium Diff Cups (HBC8019)[SIZE=2], and the Flux spiders fit inside those cups just fine; all you will need to do is sand a few thousandths off of the cross pins.
