01.28.2011, 11:43 PM
Linc, yes I am running buggy gears (43/13) with a 46/15 spur/pinion combo. With the 2200Kv motor and Lutach's ESC, the batteries, motor and esc barely get warm.
I just test-fitted the 1717 and there's a problem with clearance. There is not enough space between the can and the chassis using the RCmonster cd mount (unless I put some spacers at the base of the mount). Besides, if I use the 1717, I have to dremel the mount since a 4mm screw won't fit.
So it seems like the 1520 will be a better choice from what you're saying.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
