Thread: Soldering jig.
Cody.McP
01.30.2011, 12:33 PM
I just use a pair of vice grips to hold the connector. Then, just hold the wire and solder it on there. If you are soldering so long that the wire is too hot to hold, you are taking too long and need to practice soldering.
Hmm well maybe I am not soldering correctly, as I can't seem to get the solder to "melt" into the wire unless I get the wire too hot too hold.. Maybe I need different solder? Or maybe I'm just no good at it.
