DrKnow65
DrKnow65's Avatar
01.30.2011, 01:55 PM
Yah, the highest load you'll see is just as the vehicle starts moving. If you have a volt meter you can probe on either side of the connector (just push the leads into the backside of the connector on one wire at a time) and look for a voltage drop when you load the motor holding the car in place. Just don't do it too long and overheat anything.
Hope that makes sense.
