01.30.2011, 02:05 PM
Slimthelineman, you may want to go up to a 40/50c pack, you'll have less voltage drop and a bit more punch, which sounds unnecessary, but if you make more power you can back off the throttle even more. That will bring the temps down a touch more and keep you off the LVC even longer, which means you can size the pack down a bit and save some weight...
Sounds like a bitchen setup so far!
Looking forward to trying some of these 14xx motors in a Ofna 10SC that should hit my door around Wednesday.
