01.31.2011, 10:25 PM
Originally Posted by hyp7 View Post
Which is better or more efficient a 4s lipo or a 5s lipo? Also whats better between batterys like a 4s 40c battery or 5s 25c battery. I guess whats better the higher C rating or the higher cell count.
thanks for the help.
Well, you have a loaded question.
If you run the exact same setup (motor, esc, gearing tires size) on 4s and on 5s, the 5s setup will draw more amps and go faster, but will likely make more heat, and have similar runtimes, or possibly less. If you have a setup that can be run on 4 and 5s (not exceeding the "sweet spot" of the motor) and you regear so that you have the same top speed with either 4s or 5s, the 5s setup will be more effecient.
A 4s 40c lipo will be capable of more output than the 5s 25c. Depending on your setup, gearing, motor, etc you may be able to run the 5s 25c lipo within its limits and thus it would provide a more effecient solution.
There is a big difference between 4s setups and 5s setups in heavier vehicles. 4s is marginal, even with the gangsta never lipos that are out. Going with a slightly lower kv motor and 5s lipo in a heavier vehicle stresses the components less and will lower amp draw and thus heat.
Any help?
