Originally Posted by DrKnow65
rm, google "rc speed calculator" :-) Then use a temp gun... often
i have done so but already but its no use realy, rc speed calculator does not tell you what temperature you will be running at so for all i know i can run a 30t pinion and 20t spur. also with a tekin the timing can be adjusted which is another variable which the calculator doesn't take into account
of course i could just do some trail and error but i need a motor to base it on first, i could buy a 2650kv for example only to find out later that i cant run high enough gearing for the speeds i want as it gets too hot
thanks
