wallot
wallot's Avatar
02.02.2011, 07:19 AM
you dont need any setup station. we have HUDY and I used it once or twice. it is just time consuming and since all the slop (which is good) on 1/8 scale vehicles once you put the car on wheels the settings can be several degrees of.
this is all you need for setting up race vehicle:
board or at least flat surface
Camber Gauge - Losi for few $
Ride Height Gauge - Losi for few $
Digital calipers for getting equal length on all the turnbuckles left/right which is needed for front toe - rear toe is ussually set with toe blocks and no measurement is needed - set the Front wheels equal and then just adjust based on vehicle behavior. 40cm ruler can help you to get to 0 degree toe and go from there
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
