mothman
02.02.2011, 11:55 PM
Awesome! Thanks for the quick response.
Im ordering the IRC Lightning cups now... Ordered the HB Hardened internals and some more diff gaskets just in case...
I was considering getting the alloy diff gaskets from the hellfire... JUST IN CASE i need to create a little more space, the alloy gaskets would help pull the ring gear out a little... or otherwise ill just shim the large side gears into the spiders if there is too much play... (i doubt it though as these HB Internals are meant to be thicker than the stock savage gears) Only can wait and see...
THANKS FOR YOUR HELP AGAIN CHAMP!!!!!! asset to RCM!
If I were you, I would get the nova cup. Dimension wise, they are the same as the IRC ones. But in terms of material, nova is better since they use 7075 aluminum and IRC ones are 6082. 7075 is superior that the 6082. And I was told that the anodize on the IRC is not hard coated anodize, just normal ones, so it can help abit but not much.
