02.04.2011, 03:56 PM
Ok, modded the lst c hub to fit a savvy lower arm. All I had to do was some grinding on the outside of the hub where the lower pivot pin goes thru and it fits nicely inside of the savvy arm. Hinge pin size is exactly the same.
The upper arm would have to be the ss savvy adjustable one, as the lst hub does not sit at the samer angle as the savvy hub in order to get the axles parallel with the ground.
However the stock savvy lower arm is still too short, by about 1/4" or so. Had a look at the lst lower arms and they are just under .5mm longer than the savage. No dice there. The difference in width comes from the lst bulks, it places the inner lower hingepins wider than the savage.
So we need longer lower arms and adjustable upper arms to make the lst2 cvd in a savage a reality. So close yet so far. I will post pics later, need to get back to work.
