Shonen
Shonen's Avatar
02.04.2011, 04:28 PM
Speaking of HV, does anyone know if the MMXL can be run on higher than 8s if the motor brakes are disabled? I'm wondering if the ESC voltage was underrated to compensate for the brake spikes...
I'm not sure, I haven't tried but I believe Castle had a feature on 1.29b that flashes an LED if you overvolt a Mamba ESC. I'm not sure if this disables it from driving, but Mamba XL firmware was added in 1.27b so if it becomes a problem there is a workaround.
