Nixpus
02.04.2011, 06:10 PM
Will do... just waiting for bits and pieces to arrive from the US chop shop to Denmark :)
My toolshop buddy began the wide knuckles... made a true wide knuckle for the front and a wide hub+knuckle for the back to eliminate the tie rods and slop in the rear end.
Sounds like I should get an IRC cup for the CD btw? http://www.innovative-rc.com/lightni...ver-p-209.html
Im debating if I should try to do something like the KD direct drive with a CD or mount the motor like Jahay on the side of the TVP. The later seems really easy to adjust.
Also I am debating if I should try to fit 1717, CD and 2x5800mAh Tunigys within the standard XL TVPs, go with larger TVPs or alternatively settle with battery boxes and the weight adjustability they bring to the equation...
Updates when I have progress to show or questions to ask :)
Keep on truckin!
