simplechamp
simplechamp's Avatar
02.04.2011, 08:21 PM
Originally Posted by JasonB View Post
The sleeves on these cups that the bearing sits on are 1mm thin. It amazes me that the 7075 alloy can be milled down to 1mm and still handle the kind of stress these monster trucks dish out . . . WOW!
If you think about it though, they don't have to be very thick. The inside bore is filled by the outdrive shaft, and the outside is supported by a bearing. You might be able to crush the sleeve easily with a set of pliers, but try doing that with an outdrive in there and you can't. The joint where the sleeve meets the rest of the cup is probably most at risk of failure.
Hopefully Nova RC switching to 6061 is a good thing. Maybe it means they tried both alloys and found the 6061 is plenty strong enough, and it's cheaper so they can pass savings on to the customers. I don't know how long ago they switched, but I'm pretty sure the nova cup I have is the 7075 as I bought it quite awhile ago.
But yeah Jahay, I'd say IRC are definitely the way to go for you, especially with Nova now using 6061. Not sure on how the Hellfire cups compare to the Lightning Stadium cups. All I know is Jammin, Kyosho 777/ST-R/GT platform, and HotBodies LSP/D8/D8T are all basically the same.
