02.04.2011, 09:25 PM
If you believe and obviously seem to have tried and realised that the LST setup will not work which is a shame...
Please get some pics up...
Nope, the lst setup would not work unless you could find a longer lower arm that would fit all of the savage components.
Heres a pic that shows the lst lower arm next to the savage lower. Hinge pin sizes are identical, not that it helps...
Almost identical in length, the lst arm is about .5mm longer.
