And here are the pics of the attempted lst2 fit:
Stock hub carrier, note the raised portions around the hingepin holes:
And what i had to remove to make them fit the lower savage arms:
Another angle, before and after:
This pic shows the lst2 axle in the savvy hub. with the hex in the stock hole there is right at 4.5mm of gap:
Assembled with a savvy lower arm. I used some other items to get stuff level, and the bone end of the lst2 cvd is bottomed out in the diff output cup in this pic, note the distance from the top of the carrier to the upper arm, lower arm needs to be about 1/2" longer to get the carrier upright as it should be:
And here is a shot of the stock lst lower hingepin brace as compared to the savage one. See how much wider the pins are spaced on the lst. That coupled with the slightly narrower diff makes the lst2 cvds fit, even when the lst2 and savage lower arms are the same length:
And finally a pic of DrKnow65. He sent me this for some reason, wanted to trade? I do not understand, maybe someone else will?
