03.23.2005, 11:22 AM
The RDLogics cvds won't work with the hybrid bulks and 1/8 diffs, so you will need to go with MIP or another cvds. The titanium springs will most likely be too stiff as well, unless you onnly use 4 springs. Center shafts would also be a worthwhile upgrade. Also, are you using the stock suspension? I personally like the stock suspension, but most upgrade here as well. For the 8L (this is the motor I run) on LiPos, I wouldn't go past 14.8 volts, and make sure you have a means to monitor discharge voltage so you don't kill the cells. It sounds like a pretty solid setup.
