02.10.2011, 12:17 AM
Originally Posted by thzero View Post
Be interested to see what measurements you get for width from outside hex to outside hex.
From my measurements tonight I have:
Savage X: 14.25"
Savage XL: 15.25"
RC8T: 15.125"
I was a bit surprised by this. But on the flip side, the suspension arm is longer so the you should have more suspension travel. Also, the axles and extenders are far more robust than the Savage junk.
Should be around 30mm more than a stock flux. Do you measure at ride height or while the driveshafts are parallel with the ground?
