02.12.2011, 06:19 PM
Just in case anyone was wondering, the spacer I use was a cable stop that I found at the local hardware store. It is made of al, and is designed to be crimped on a cable, looks like the stock hole in it is about 1/4". All I did was drill it out to 6mm with a 6mm drill bit. It was just the right length, right at 8mm. Depending on how you mod your hubs to handle the 6x12 bearings you may have to sand some material off this spacer, or add a shim or 2. Fow me it was just about right, I removed some material so I could use a 6mm id traxxas teflon washer behind the axle pin.
