JasonB
Flux Fan
02.13.2011, 10:18 AM
What kind of oil/lube are you using?
Back in the day, Sikeston34m was using stp oil sabilizer. Thick stuff, and it really sticks to the gears. He was not having a leak issue like you are having, and all he did was use rubber sealed bearings. Pretty sure the stock bearins are rubber sealed in the flux anyways.
I'm using STP Oil Treatment (link) and stock rubber sealed bearings. Perhaps Sikeston was running less RPMs back then. Mine leaked like a sieve, everywhere except the parts I had siliconed together. My transmission has seen over 1 year of heavy use, so perhaps a new transmission won't leak as bad. I think I can seal it up well, but that will take a complete break down and clean up again . . . for that I'll wait till this gear gives up it's ghost which hopefully won't be for a very long time.
