simplechamp
simplechamp's Avatar
02.14.2011, 10:47 PM
"Logs pack current to +/- 100 amps (150 amps with MPRV4-LEADS-150) and voltage from about 5 volts to 80 volts"
That is for the V4, but I assume the V3 probably has same minimum, even though it has a lower maximum.
EDIT: Checked the EagleTree V3 page on HobbyKing and that says 4.5V, so 4.5-5.0V sounds about right.
