02.15.2011, 12:59 AM
I am sure your rawbuns could use some. Make Jeff a happy man!
Best way I found to apply the slime to the o rings is to place the o ring on your thumb, put some slime in the center of the o ring and then put your index finger on top of the o ring. Squeeze together and roll your fingers a bit. The shock shaft will rub most of the slime off when you push it thru, I also suggest smearing some of the slime on the shock shaft. Dry o rings seem to be the main cause of shock leaks. And silicone oil is a poor lubricant. The slime is a must have.
And rawcheeks is right, 2 tubes will last a long time. Buy 2 just in case you lose one, I did.
